many thanks for that i had read the tech spec but it makes as much sense a chocolate tea pot.
we are building a workshop which is partly sunken. i.e. one wall is below ground level and will butting up to a brick filled gabion basket retaining wall i have attached a picture of where it will be going as well as a copy of the drawing this may make more sense below
The block work shown on the plans is to be built in front of the Gabions the reason for this is the gab ions are supporting over 2000 tonnes of soil behind them. As per the Plan we will build a 3 course thick wall. The first will be block work which have the membrane attached to it. We will then build a double skinned wall for the the work shop and back fill between the Gabon and the first wall with gravel for drainage. Hope this is clear Jon.
