    Dismiss Notice
Bleed Valve Issue
Discussion in 'Plumbing and Central Heating' started by johnberman, 5 Aug 2014.
  1. johnberman
    johnberman
    26 Feb 2014
    19
    Thanks Received:
    Surrey
    Country:
    Hi
    I have installed some radiators, they are the old school type. At the top I want to add a bleed valve, so I have put one in and used PTF tape on it etc, now I screwed it in but it leaks, if I screw it to far it will simply fall inside
    as there is nothing to stop it.
    Is there a special type of bleed valve required ?
    Regards
    John B
    [/img]
  2. Sponsored Links
  3. stardanny
    stardanny
    14 Nov 2007
    1,660
    Thanks Received:
    256
    Buckinghamshire
    Country:
    • Thanks Thanks x 1
  4. buck51
    buck51
    15 Feb 2008
    894
    Thanks Received:
    103
    Manchester
    Country:
    It looks to be bigger than 1/2 inch, you need to fit a bush down to 1/2 inch
  5. buck51
    buck51
    15 Feb 2008
    894
    Thanks Received:
    103
    Manchester
    Country:
    Can you post a photo of the vent along side the the tapping so we can see both
    • Thanks Thanks x 1
  6. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,034
    Thanks Received:
    9,420
    Hertfordshire & London
    Country:
    Perhaps that tapping was for the flow pipe? ;).
  7. johnberman
    johnberman
    26 Feb 2014
    19
    Thanks Received:
    Surrey
    Country:
    thanks for the feedback, its 1 \ 2 inch - i had a valve but it was the type that screwed in with no flange so was hard to tighten
    john b
  8. jeff the gasman
    jeff the gasman
    8 Dec 2007
    12,881
    Thanks Received:
    4,551
    Cheshire
    Country:
    Use loctite thread string. Works every time.
    Jeff
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
