i suppose this has been asked a million times 2 of my radiators upstairs need bleeding couple of times a week no big problem just nuisance value anyway to solve this problem thanks P M
the rad in the bathroom has had air inside for a long time the little bleed valve is knackered so ive got to take rad off wall drill out bleed valve and insert a new one, maybe then when thats ok it might cure the other 2 rads maybe not
