i am having to bleed 3 rads once a week but all my others are fine,8 others in total,the 3 that need bleeding every week are the 2 towel rail rads and a downstairs rad.why am i having to fill these on a weekly basis and not the others ?
the towel rads are directly above the rad but no valves or joints ar leaking water as i have no wet floors or ceilings and no water present on the pipework and i dont know if the bottom rad is losing water before the 2 towel raails are losing theres as i am filling them up at the same time starting with the highest first
if it is hydrogen in the pipes is it a costly thing to eliminate it and prevent it from comming back.i will try the test on sat morn as ive bled them again yesterday.would this also account for the noises i get from the central heating system and a couple ofthe rads.
