Scenario: Around 1991 I installed a Rothermix thermo shower mixer at chest level and an outlet for the fixed shower head about two feet above it, all set in recesses that I cut out of the clinker block inner skin of the wall to the bathroom. I used compression jointed pipewrk with Bosswhite.
It all worked fine. Soon afterwards my making good grout was covered when a contractor tiled the bathroom floor to ceiling.
After a few months the hot water suddenly stopped getting through and so only cold showers were on the menu. We carried on by using a flexible-lead shower from the plain mixer tap that I had fitted to the bath during the bathroom upgrade. Not being a dynamic man-of-action I have allowed that situation to exist now for twenty years. But now the bath and fittings are being renewed again, and I want to make every effort to get this impotent fixed shower working again, while keeping the wall tiling intact.
I can't escape the conclusion that I was too liberal with the Bosswhite and the blockage results from a surplus that has built up somewhere and nicely solidified. A Fernox product was suggested to me in the early days, but then I learnt that its use in domestic plumbing was forbidden, so I didn't pursue it. I can get to the H&C feeds under the floorboards quite easily and I am thinking of feeding compressed air into the HW pipe up to the mixer, using my tyre inflator which shows a max pressure of 350 lbs/sq.in. Possibly before that I would apply mains pressure.
That is Idea No. 1. Has anybody got suggestions, ideas, brainwaves, or miracles that could be applied to this, please?
Idea No. 2 is that I isolate and seal the hot feed from the floor to the mixer, then I fix a non-return valve to the HW pipe coming from the calorifier, then join that hot feed to the cold feed via a T jct. (still under the floorboards) so that when I turn the mixer on it draws both H and C water together, but up the cold pipe only, into the mixer. I believe the thermostat will still activate under these circumstances - so in theory I should be back in business. What do you think? Is this a practical plan or is it a pipe dream? Pun intended.
Please bear in mind that I have waited twenty years for all the brilliant responses I now hope to get from all the experts out there. Please don't let me down.
