Hi all,
What a time for the CH to pack up..-5 outside
Have a GlowWorm Ultimate 120, vented system and a nearly new pump. Recently had a blocked feed pipe to one of the downstairs rads. Not the end of the world and lived with it.
Yesterday, the boiler started playing up. It would fire up fine, stay lit for about a minute and then would start banging - best description is that its similar to the sound made by a manual pilot light switch on a patio heater. The banging seems to be centered around the flow pipe to the boiler where it enters the cast iron tank. About 5 seconds after the banging starts, the boiler shuts down.
Trying to kill a couple of birds with one stone, I drained the system completely and cut out the section of blocked pipe. It was scale / rust which had formed a plug in a 15mm elbow where it spurred off the 22mm main pipe.
Anyway, filled the system, bleeding rads as I went and added a decent dose of Furnox cleaner into the expansion tank.
The boiler noise and cutting out still happens
. To start with, the downstairs rads were heating up but upstairs were barely luke warm. Now every rad in the house is stone cold.
The pump seems fine. Header tank is full (and steaming ??). The downstairs rads are air free - upstairs rads keep getting air in and there doesn't seem to be enough pressure to either fill the rads or even flush the air out...
Apologies for a long winded post and thanks muchly for any suggestions for a next step forward...
