Hi, new to forum but have been reading it for a while, I have a blocked return pipe (10mm) on a downstairs radiator, I changed the rad and both feed and return valves but its still not working.
I drained it down from the feed line and it was clear free flowing water, however when i disconnected the return line nothing come out, i tried to clear it using instrument airline (6 mm) initially it wouldn't go further than 2 inches in but using a little force it went in and i got some black sludge out.
I could only clear around 10 inches as it stopped at an elbow but i started to get a dribble of water out.
I put it all back together and tried it in the hope it would force water through but it didn't.
I have a RGI coming out on Wednesday to see what he can do, do you think he will powerflush it or try to replace the pipe, I would rather he didnt replace it as its behind plaster board and it looks like it would be messy.
Any thoughts would be welcome as would some idea as to how much it would cost as I dont have a clue.
The system is around 12 years old and has been treat with fernox a few times due to house extensions and a pump that needed replacing a few years ago.
