Blowing Light bulbs
16 Jan 2004
Why should the lights bulbs in my house keep on blowing, on a regular basics? If anyone has any theories (besides cheap light bulbs) please let me know.
PS. The property is damp free..
Well cheap lamps are the number one cause. Are you trying to say you have good quality lamps but they still fail prematurely?
Filament lamps rated at 230V will only last about 55% of their rated life when run at 240V.
Davy
Old worn out lampholders, lamp wattage too high for ratings of shades, voltage spikes, loose connection on lighting circuit
Relax !!! This problem does not mean you have a major wiring fault. This is a never ending problem which has been looked into for donkeys years. A wiring fault in your circuit will be picked up by fuses and MCB's long before it gets to the bulb.
There are a few reasons bulbs can blow, the major one being cheaper bulbs. The elements in cheap bulbs are much thinner and any surge of power, however slight, simply breaks them. Always go for expensive light bulbs, its cheaper in the long run.
A loose connection in the lamp holder can also cause bulbs to blow. This is because the circuit is not completed as tightly as it could be and the electricity may have cause to "arc" or jump across the contact, rather than simply flowing through it. When this happens it produces more heat in the fitting than is expected or catered for by the bulb, and the bulb can blow.
The same can happen if the spring loaded connection in the bulb holder is slightly loose. This will cause electricity to arc across the contact, cause too much heat and blow the bulb. This can very often be diagnosed by looking at the contact on the bottom of the bulb to see if it is pitted. Arcing electricity effectively melts the metal it is arcing onto ( This is how arc welding works) so if the bulb contact is being subjected to arcing, tiny little indentations occur, called pitting.
It is sometimes possible, if the live connection in your light switch is a little loos, for this to happen here also. Heat will be generated and it is possible, though very very remote, for the bulb to blow as a result of this.
When a bulb blows, 99% of the time the fuse for the lighting circuit will blow or trip also. This makes the problem seem rather bigger than it actually is. The reason for a blowing lamp tripping an MCB is that the lamp element gets thinner during its life to the point where it breaks at the thinnest point, this point will melt just before failure. The resistance of the overheating element will momentarily be very low and a current surge is caused, this is picked up by MCB's but generally not fuses.
So, three things to look into if your bulbs keep blowing. Your bulb supplier, The wire connections inside your bulb holder, and if the spring loaded connectors are working properly inside the bulb holder. As a last resort you can also check the tightness of the connections in your switch.
I wish to thank all those who have given me advice to date.. Thank you.
I will act upon your advice.
Someone did also suggest that I may have a loose Neutral in my lighting circiut.
Start converting to CFLs (Energy Saving lamps). Apart from lasting for years and saving you money on electricity, they are much more tolerant of supply voltage fluctuations.
Most incandescents blow when first switched on as the cold resistance of the element is lower than when it has reached the operating temperature.
So, switching the lamp on when hot would help, for example when it is midday (during the summer).
Frequent cold switch on' s will reduce lamp life as will the factors previously alluded to by others. Being shot with air rifle pellets is one suggestion that is noticeable by its absence, though.
