Bathroom light keeps blowing
5 Feb 2007
Liverpool
My bathroom light kept blowing I changed it to a pendant, it was a circular type bathroom light with the glass over top (Bayonet bulb). When changed to a pendant fitting the bulb kept blowing so I got a spark to fit me a brand new bathroom light fitting with G9 bulbs. Light is still blowing. My extractor fan in my bathroom is not working, could the steam be making the bulbs blow. I know it is possible but on 3 fitting ?
are the lights suitable for the zone in the bathroom that they have been fitted in ?
Thanks for reply guys. I would not say cheap lamps as its doing it on 3 different fitting with 2 types of bulb. The light is in the right zone it is a ceiling bathroom light.
Are lamps blowing causing the trips or is the circuit tripping with lamps(AKA bulbs) blowing.
It is very common for cheap and poor quality lamps to blow and this will often trip the MCB, especially the halogen type.
It would be worth, consider purchasing a higher quality lamp type and if that still causes issue ask the electrician to come back and check for faults on the fitting, such as loose or damaged cables/wires and also look at the lampholders. It would also be wise to check out the conditions of the cables that are connected via light circuit to fitting.
If it is a fitting issue, you can return and have replaced.
