- Joined
- 6 Aug 2004
- Messages
- 502
- Reaction score
- 5
- Country
Are we there yet?
Freddie said:jbonding said:its probably blown because you never applied a scratch coat and applied in one coat.
But all internal hard wall of sand/cement is one coat over here, if it were 2 coat no door frame would fit.
jbonding said:Freddie said:jbonding said:its probably blown because you never applied a scratch coat and applied in one coat.
it doesnt matter where you live sand and cement is applied in atleast two coats have you not learnt anything yet![]()
legs-akimbo said:jbonding said:Freddie said:jbonding said:its probably blown because you never applied a scratch coat and applied in one coat.
Errrrrr! Not so at all at all atall J B....In fact many spreads lay on one thick coat of render, particularly on a doorless windowless wall rule it off fill in the slacks rule it again and half an hour later float and devil it. Job done. Personally I like to lay on a tight coat immediately after the first as this will rule with an 8Ft feather edge closed up to perfection...No slacks and will float in seconds when ready. Like I say after twenty more pages!!!!!!!!.
dougalhouse said:Legs,
What does 'devil it' mean?
dougalhouse said:Freddie,
I learned
1.) Not to use PVA as a cure for everything (see another of my postings where I trusted it on an artex ceiling and the whole lot came down as I was giving it it's final trowel!) Mechanical key is the best
2.) It's not good practice to use waterproofer in the scratch coat.
3.) That the floating coat needs to be weaker than the scratch.
4.) There is more than one way of doing things and different people use different (but equally as good) techniques.
5.) That things haven't changed for 15 years with building site / inter trades banter.
6.) That english tradesman are now emigrating to Eire to work (how things change) I bet there are no signs in the emerald isle on hotels, pubs, shops etc saying 'NO ENGLISH WELCOME'![]()
7.) That some people have alot of time on their hands spending hours helping others on web sites like this, for which I, along with many others are eternally grateful for!
I would still like to learn what deviling is tho. Legs said you do it after floating. I'm assuming it means floating again with a steel trowel for a smoother finish![]()
legs-akimbo said:O the Irony about not finding work here.....from a geezer who spends his days on this forum, because he ...errrrrrrr hasnt any work!!!!
You have no idea as to why I live in Ireland J bonding, and as for working in England as I have said, and you are the living proof of, its all tuppence hapenny work being a plasterer in the U.K. a monkey could do it, the real artisans of the trade are few and far between. You do have to step away from your front door to be able to hold a valid opinion J.B. if you have no experience of other working practices and methods, or anything at all in your case then you really should not be making such a mockery of yourself.
