Hi all,
Firstly, sorry about the pics, I haven't been able to sketch-up working, so this is my attempt using Word's drawing tools..
I intend to board out a section of the loft to store the usual rubbish. I intend to cross batten the original fink roof truss, which has a 100*35 joists at 600 centres, with 4*2 cls at 400 centres (width of the existing insulation), and then fit 18mm loft boards (1220*320) from Wickes.
Key to the roof truss piccy below. Width of entire truss (front to back of house) is approx 6800. Distance between nodes of truss where I plan to board is approx 2220. The green lines are the load bearing walls. The red rectangle is the area I intend to board, area = 4200*2440 roughly. The furthest truss is up against the party wall. The rectangular splodge is the loft hatch. See above apology re. Word..
As you can see, the load bearing wall will take up the slack on two sides with the party wall at the end taking up that end's load. I'll be joist hanging the cross battens direct to the party wall directly above the joist. The blue line shown in line with the LB wall is a doorway.
Below is the layout of the boards, catching a batten for the ends of each board
I'll be skew screwing the battens to the existing joists, and as I'll be using 2400 4*2, I'll alternate the battens 2400-1800 and 1800-2400 to cover the length of the floored area, and with the 600 offcut, I'll glue and screw it to the side of the join, sort of creating seven 4200 battens in effect. I'll then screw down the boards as shown. I have no plumbing to worry about, except for one stack pipe inside one of the nodes, and the only electrical that I have under this floor is the landing light next to the hatch, fed from the right as you look, and switched from the left. As those cables are under the first row of boards, they can be accessed just by undoing a few screws, rather than having to worry about the T&G in the middle of the floor.
I hope this enough info..
Is it going to be OK to continue?
Thanks in advance
Liam
Thanks in advance
Liam
