Boarding Out Loft In Steel Framed House
14 Apr 2016
Hi All,
Looking for some advice about boarding out my loft and I can’t seem to find the answers elsewhere to my particular situation.
I live in a steel framed house and in the loft the joists are 150m deep. There is insulation up there which is much higher than the joists. With the steel joists, loft legs are a no go so I've decided to board straight on to the joists.
My question is should I A) remove the excess insulation above the joists or B) just squash it down and put the board over the top? (I plan to use tongue and groove OSB Board)
Any advice gratefully received.
Hi All,
Don’t remove the insulation, but also don’t squash it heavily under the boards. Best approach is to leave the insulation at its proper thickness and create a raised layer above it (timber battens or a suitable sleeper system) before laying the OSB boards. Boarding directly onto the steel joists will compress insulation unevenly and reduce its effectiveness.
