A big posting but in trouble here!
Can anyone who is in the trade tell me if the following jobs done are passable or do they need remedial action please?
My parents have had a bathroom fitted by someone who was highly recommended, but instead proved to be total £!&*£$% who made a few nasty bodges, most of which can/has been put right, but the following still concerns me ;
1.They replaced plaster board after knocking off the old tiles, except for one wall, where they nailed plaster board over the old.
2.They didn't treat it with any PVA.
3.The rendering came off one supporting wall, and they used plaster that is intended for areas that have low porosity, (no finishing plaster) then tiled over it the following day.
4. They silicon sealed around the shower unit but, they left a big hole (3" square) behind it for the power and water supply, and am able to see the plaster board.
Should this be tiled up to prevent water getting into the plaster board, despite having the silicon sealant around the shower unit?
5. They used a sealing strip that appears to go under the tiles then over the rim of the bath, but does not meet the bath properly, which will obviously leak. and mitred the corners of it, leaving a small gap for water to get at the plaster board. I can't seem to get it off without pulling the tiles off with it.
the tiles are big: (25cm x 33.3) Can anyone give me advice on any action that I may have to take to prevent the tiles coming off?
Could someone give me advice on anything i can do about the above, and if not, then if the tiles were to start falling off, would they come straight off without warning or would there be tell tale signs first? e.g cracks in the grout.
many many thanks in advance.
