Hi all,
I had a problem with my Glow-Worm Fuelsaver F boiler that didn’t want to switch off. I checked the Honeywell L641A hot water cylinder thermostat and noticed that the small switch inside had seized. I immediately replaced the thermostat and wired it exactly as the old one.
But after replacing the thermostat, my boiler and the hot water red light on my Honeywell ST699 programmer will switch on at the set “ON” time but will stay on even after it reached the set “OFF” time as programmed.
Eventually, the boiler will stop but the red light will still remain lit.
The boiler thermostat dial is set between 4 & 5 and 55*C on the cylinder thermostat.
I read through many forums but got mixed solutions to the problem. Some say it could be the controller while some say the motorized valve is not closing. I don’t want to replace one of these only to find out that it was actually the other that caused the problem.
I would really appreciate any feedback on this.
Kind regards,
Johan
Kind regards,
Johan
