My CH system has an (old) Ideal Classic heat-only RS boiler, Grundfoss pump, hot water tank, two Honeywell zone valves, Honeywell ST6400A timer and Honeywell CM67 room thermostat.
(The zone valves were recommended and fitted after problems with a three-way valve.)
Everything worked fine until recently when the heating just stayed on regardless of changes I made to the thermostat. The pump runs all the time and the only way to turn the heat off is with the boiler thermostat. Switching off at the timer doesn't do anything. A few days before this happened the heating wouldn't come on at all. but eventually did after I switched the room stat on and off a couple of times, which made me think the thermostat was the problem.
I called Honeywell and explained the circumstances, telling them that the thermostat is about six years old. I was told that the thermostat might be the problem, so I changed it to the replacement for the CM67, which is the CM907.
Same problem. Now I am wondering if the zone valve is stuck open. Any ideas, anyone?
I also have some questions about how the components work with each other.
I mean, when the thermostat calls for heat, where exactly does the signal go: to the zone valve?... boiler?... or pump?... or combination of these? How does the signal from the thermostat(s) travel to start or stop the system.
Elementay questions, I know... probably several variations to the theme... but my system set-up is over 20 years old... can someone give me a clue so that I can understand how the components communicate with each other? (Or recommend a book)
