You want expansion as close to neutral point on the system, return is cooler so in theory better for the diaphragm rubber.
Those are four way mixing valves in your drawing.
Will the boiler controller accommodate two?
Seems overkill for a small property. And they are expensive.
Though I expect the gravy train will pay for it.
So your boiler controller can receive info from two flow sensors and mix the temperature to the appropriate zones accordingly though the four way mixing valves?
If not then I see no point in having two.
Weres the buffer vessel ? Blending valve to stop back rot etc. heatleak rad with closed 2 port in case of power cut. Has any off this been discussed ?
What link ?
