On two occasions now (Monday this week AM and PM and again today) we noticed that our boiler was on when it shouldn't have been.
Wondered if anyone could shed any light on what might be causing the problem?
I noted down everything that I could:
1. The boiler fires up outside the times set on the timer.
2. When this occurs, the boiler fires up, displays C (meaning that heating or DHW is being supplied) and the burner light stays on.
Then the boiler quietens down (stops pumping or burning) and the C remains on but the burner light starts flashing again.
Then the process repeats.
If I turn off the power to the timer and the boiler (same wall switch) and turn it back on, the process then seems to repeat i.e. as soon as you turn the switch back on, the boiler fires up, C light is on and burner light flashes.
Turning the boiler off but leaving the timer on doesn't seem to make any difference. In fact the boiler fires up and on immediately after turning it back on.
Setting the timer to off on both heating and water and then power cycling the boiler seems to resolve the issue. We can then put the timer back to the timed position for water and heating.
It's happened twice so far: Monday this week and then again today (so 4 days in between).
In terms of hardware, we've got the following:
Ideal ICOS HE-15 Boiler
Drayton LP522 timer
Drayton thermostat
Thanks in advance
Drayton LP522 timer
Drayton thermostat
Thanks in advance
