Hi
I have an open gravity fed system with an old Ideal Concorde WRS boiler. A few months ago the rads weren't heating up downstairs so I went through the usual process of turning off all but one rad etc, this would normally work for a short while so I thought it may be a balancing / air lock issue but recently had all but one rad turned on and still no heat.
Next step was to check the pump, I removed the top screw and the impeller is defnitly turning and humming. For the first 4 years of moving in everything was fine!
Over the last couple of years I've done a few DIY jobs on the rads so I thought maybe there's a severe air lock so tonight I comeplety drained the system and now no heat in any of the rads! The hot water is fine though.
I started to think back on what I may have done. One thing was to remove the thermostat from the wall last summer and join the two red and black wires together before taping it up and sticking it in the walln then sealing it over!!!! (lol). Maybe this caused the problem but wasn;t noticed till winter time. The other thing is that currently the boiler kicks in but cuts out after a few mins. On the front of it there's a temperature dial saying Off, 1-6. When it cuts out if I TILT (not turn)i.e press down at 12 o'cock it seems to kick back in put when I let go it cuts out!!! What could be making it cut out? Could it be the thermostat or something more serious. This is driving me up the wall as we now have no heating and the wife is going to wake up in the morning with a frying pan in hand!!!
Any help please?
Any help please?
