boiler does not fire when timer comes on - unless HW also on
With the meter set to continuity you get a beep when the two probes are touching each other and in the same way a section of wire can be checked for breaks by placing the probes on each end.
If the wire is OK it will beep (and may also give a very low reading of resistance.)
Alternatively if you can figure out a way of safely measuring the voltage of CH ON directly at the back of the programmer backplate, that should indicate whether the programmer is faulty.
Just run the continuity test and the instructions say there is an audible warning if below 50 ohms.
The warning goes of and the reading is 003. Unfortunately I cannot interpret what this means. Is it just the wire that has broken and would it be worth replacing this before I replace the timer?
That indicates the wire is connected OK so the timer must be faulty.
Oh it appears the audible beep is a good think and not a warning, sorry a total novice at this!
Seems to me it is the timer!
