Boiler dripping
Status
Not open for further replies.
5 Feb 2005
:( My Vaillant Combi boiler is dripping. I have recently drained the system and when I filled her back up it seems she is dripping from the AUTOMATIC AIR VENT.
Any suggestions please??????????
what pressure is it reading on the gauge, it should be 1-1.5 bar cold.
My system is working fine. Rads all at set temperature and pressure is at 1.5bar.
However system is just dripping from the automatic vent???
do you mean the auto air vent on the top of the boiler or the pressure relief valve that goes through the wall
Thanks for the replies.
Yes, it is bubbling out of the Automatic air vent on the top of the boiler
Theres a float chamber bit like a carbaretta on a car, it can with care if you drain some water off to relief the pressure be taken apart and cleaned
what model boiler is it, hopefully I have a manual someplace on the cd
Doitall,
Sorry for the delay, I got called away on an emergency.
VAILLANT VCWGB 242 E B.
What do you think is the problem? is it a common fault?
Regards
read my last post.
auto air vents quite often leak and yours probably has a bit of grit stuck under the seal.
if you drain the water out the boiler (after you isolate the electrics) the valve can be serviced.
Doitall,
Thanks for the advice, us part time DIYers really appreciate web sites and people like you.
Thanks again
Paul
Status
