About 12 months ago I had a new baxi platinum combi installed, and it would fire when the cold tap shut off - presumably down to a sensitive pressure switch or something. I installed a mini shock arrestor immediately before the cold feed to the boiler, and this seemingly cured the issue.
Now recently I've had the heating circuit drained a number of times to undertake some works, and now that it's refilled, I have the same issue where the boiler is firing when the cold tap is closed. I've checked the shock arrestor pressure, and it's still fine at c. 3.5bar.
Any ideas what else I could/should try?
Would a double check valve in the cold feed to the boiler help?
Thank you.
Thank you.
