Hello all,
I’m pretty clueless when it comes to this sort of thing but as we can’t have tradesmen in the house due to shielding I’m hoping someone can give me advice to help diagnose my heating problems. We bought this house less than a year ago and starting to find that there are several little ‘problems’.
We have a Potterton boiler, with a header tank in the loft and an immersion heater in the airing cupboard. It’s controlled with a British Gas UP2 wall controller and we have two thermostats - a satchwell in the living room and acl Drayton at the bottom of the stairs. The valve in the airing cupboard is also an ACL Drayton.
Our heating and hot water was working fine but has recently started playing up.
When I press the wall controller for hot water the boiler starts running and producing steam and it heats the water up.
When I press the wall controller for central heating nothing happens. The thermostats are set at maximum temperature. And the heating still didn’t come on even when it was very cold.
We were told to replace the motor in the motorised valve so did so. It didn’t make any difference.
When I push the lever into manual we get heating.
Someone said that the actuator might be broken so we’ve purchased one of those but the valve needs replacing too because it’s so old. So before I mess around with that I’d like to check to see whether I’m doing the right thing.
Please can someone point me in the right direction?
