Hi - I have a Worcester Bosch 24SBi Boiler set up as a Y plan system with the boiler used as the wiring centre and with a built in mid-position diverter valve and a built in digital programmer. The boiler heats water in a cylinder which has a thermostat, and the central heating which has a room thermostat. You can see on the digital programmer when either or both thermostats are calling for heat. The system has been working fine for about 5+ years.
Just recently the central heating stopped working, even when the thermostat called for heat. The water is still heated. I thought it was the mid-position diverter valve and put in a replacement one. Unfortunately this has not worked and there is still no central heating.
I have thoroughly bled and got all air out of the system, but still no joy. Any suggestions as to what to try next?
Thanks.
Thanks.
