boiler keeps switching off and on
27 Oct 2011
Blackpool
Just had a boiler installed by pratts ltd. Works ok on heating only but on water only, it comes on for two mins and off for two - on for two etc continuously. any ideas? Its a Main HE pumped unit.
Get the installers back,also post in the plumbing section,they will help you out.
Thermal overload cut-out protection? Are you sure the water is flowing through the hot water circuit, and there are no air locks?
If I were you (Since you got a company to install it) I'd call them back and get them to fix it, it's part of the job.
If you start tinkering with it yourself you might void any warranty they might honour.
my guess, Sounds like thermal cut out devise (OH Thermocoupler) ...baxi will have the boiler under warranty for 1st yr min, so it likely the company who fitted it, will contact baxi (baxi/main) to fix...call them out...
