Boiler Leakage
25 Feb 2007
Blackpool
Hi i have a problem with my boiler. I suspect my boiler is maybe leaking, water is coming down from the chimney when the heating is switched on for the domestic hot water storage tank. The water is falling onto the gas ring behind the gas fire. It is also drawing in air evereytime its used, I am having to vent air off the hot water circulating pump everytime it is used. any advice would be apreiciated thanks.
Do not use your gas fire until checked over by a CORGI and get him to check your boiler and/or pipe work in airing cupboard or whever it is for keaks and damage.
This sounds as though it needs immediate attention
