Hi. I'm having problems with my Halstead Finest Platinum boiler. The system can run fine for a few hours then shuts down into fault mode. This can be for no apparent reason or sometimes when there is a call for hot water.
The boiler diagnostics show a water pressure fault. Once the system enters fault mode it can be difficult to restart the system. Often it wont restart at all although strangely it always comes back on the following morning when the heating fires up. And again, runs fine for a few hours.
When it's in its fault mode the pump continues to run (don't know if that relevant??)
Anyone got any thoughts on the most likely cause?
