Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Just had a new pcb and fan on our Vaillant 837e turbomax boiler (non condencing) and now have a clunk from boiler when turning the hot water on, when the boiler is in heating mode. Any ideas?
Current part no. for the revised PCB is 0020034604. The diverter valve is moved in gradual steps rather than one motion. Also known as the 'galloping horse' board, as thats the noise the DV makes as it changes
Long horizontal runs on the heating circuit (i.e. bungalows) seem to make this problem worse. You can check if its the correct PCB by looking on the top lhs of the board and it will have three adjustment potentiometers that are not on earlier pcbs. These are for the 'pro' range of boilers, and this one PCB now does all variants.
Range ceased production in 2005 with advent of ecoTECs, merchants had them available for a while... but were only allowed to be fitted under dispensation of building regs part L.
