Boiler noises
3 Jan 2007
London
Hi all,
I have a Glow-worm Compact 80E that has started to make some strange noises. When you turn on the CH or DHW I hear a noise from inside the boiler that sounds like an hydraulic lift or maybe a electric drill or saw. Once the CH or DHW is turned off, the noise can still be heard for a few minutes. Sometimes the system does work as normal (without the strange noises). I know its not the best description but any ideas what the problem could be ? Heating / DHW working fine but I don't want to wait until the system breaks down before getting some advice.
John.
HI
1.pump partially blocked
2.boiler stat faulty which can cause boiler to overheat and pipes to rattle or bang
thanks, to unblock the pump, would it be worth draining / cleaning the system or just try to bleed it - thanks again
also, the noise is comming from inside the boiler, not any of the pipes. I can hear it now, sounds like a loud dentists drill
HI
you can buy sludge remover /central heating cleaner for heating systems
which should eliminate few problems .scale buildup,etc.
