boiler not firing up
10 Sep 2009
Norfolk
hello
i have a problem with the central heating system. When the hot water is switched on the boiler fires up but it does not fire up when the heating is put on. Also when the hot water is put on all the rads get hot. I thought it must be a port valve stuck but i cant find one.
Sounds like the valve is stuck in mid-position. They are usually in the airing cupboard next to the hot water cylinder.
can't seem to find a port valve, would there be a system where a valve is not used.
If you have a gravity hot water system with pumped central heating (i.e. old system before valves were used) then it is necessary to have the hot water on before the central heating can be operated. On the other hand you could have a combi.
There's a lot of guessing going on here, you need to provide us with more information. The make and model of the boiler would be a start.
its not a combi its a trianco tro 15/19. when you slide the water on to run the boiler fires up but if you slide the heating onto run it doesn't fire up
You may well have gravity hot water pumped heating, in which case your pump is only used for heating, and if pump has failed, seized, stopped working, no heating.
thanks i'll dig a bit deeper. and nothing has happened to the micron its not my c h system.
