im an electrician, recently wired an s plan central heating system for a vaillant 656 ecotec system boiler. The central heating works fine and the boiler fires up when the room stat calls for heat, however the hot water is not firing up the boiler even though the two port valve is working as it should and the switchline back to the boiler is bcoming live via the hot water cylinder. the switchline for the boiler is on terminal 4 which fires up the central heating. Is there a seperate terminal for hot water? help
