A couple of years ago we had a WB Greenstar 28i Junior fitted.
I've noticed a couple of things I thought I would mention / ask about.
The guy who installed it piped the condensate straight outside into the gully, didn't increase the plastic pipe size to 32mm and didn't fit a condense sure siphon or lag the pipe.
The filling loop was also left attached.
Should I, (as a temp solution for condensate): -
Just lag the pipework?
Will the fact it's only 22mm cause a problem?
I will be getting a gas safe plumber round to run the condensate correctly to my sink waste, since it's only 1/2 meter away, at some point in the future.
With regards to the filling loop, should I disconnect it?
One other question: -
I have a 15mm magnetic scale inhibitor fitted inline on the DCW to the boiler, does this require any maintenance?
