Boiler type two month old Veissmann 100 W combination
System is depressurising by about 0.5 bar a day. No apparent leaks in pipe work radiators etc but as usual there are areas that can’t be seen.
To see if problem is fully or partly with the boiler I closed flow and return valves when water cold and pressure 1.5 bar. Pressure reduced by 0.25 bar overnight. No apparent leaks when valves closed. However when returning the valve on the return to open, water sprayed from the spindle. It sealed again when valve in fully open position.
No leaks apparent at the PRV expansion outlet. Pressure when central heating on is 2 to 2.25 bar
Fitted the boiler myself. Gas connections and commissioning done by Corgi engineer.
Fitted to an old system but chemical and mains flushed beforehand and Spirovent dirt cleaner fitted and chemical inhibitor used. Circulation water seems to be clean.
Do the symptoms I have described indicate a fault in the boiler, if yes what might it be before I contact the manufacturer and ask for a warranty repair. The commissioning engineer is, quite reasonably, unlikely to see it as a problem for him to resolve
