I had a new boiler fitted last December, a combi to replace an ancient gravity fed system. I read lots of horror stories about old systems possibly springing leaks due to the increased pressure, also I have a mild form of OCD which means I can't stop monitoring it.
It was set at 1.2 bar, exactly on the line, when the system was cold (there's a digital display on the boiler telling you the water temperature - in the mornings when the heating has not been I always make sure this reading is the same when I check the pressure gauge).
Over a few weeks, this drops by extremely tiny amounts, no longer exactly at 1.2 but maybe 1.18. I crack open the top up tap fractionally for literally half a second to get it back dead on the line. No more than a thimble full of water was probably added.
When you read about leaks on here, people talk about it dropping 0.5 bar in a week or two. Ours has probably dropped 0.2 bar in the 9 months we've had it, so I'm not unduly worried about a major leak, it's just that bloody OCD of mine doesn't like it changing!
Oh and the boiler manual mentions it has a natural air bleed valve on the pump so check and top up the pressure every few months, but being me I choose to ignore that face and still get paranoid I have a leak. (because the heating hasn't been on for 3-4 months so the pump hasn't been running).
So - is such a tiny drop (0.2 over 9 months) anything to worry about, or do boilers naturally lose extremely small amounts of pressure over time??
