I have an Alpha Intec 28S System Boiler and over the past few weeks the system pressure kept dropping slowly and needed re-pressurising every week up to 1 bar. I then noticed that the system boiler pressure was rising to 3 bar when the heating was full on up to temperature. I had also noticed that the PRV outlet had discharged at some point as there was some browning stains on the roof below the outlet outside.
Overnight when the heating is off, the system pressure has been dropping to zero and the boiler wouldn't fire up in the morning.
I called out my Gas Safe plumber who actually fitted the new boiler originally about 5 years ago when he relocated it from the downstairs utility room into the loft.
He has replaced the expansion vessel and PRV with new ones. (Although he didn't actually feel there was anything wrong with the old expansion vessel as some air came out and no water)
He was convinced that this would solve the problem. However, it didn't.
He came back yesterday and removed the pipe connecting the CH flow side to the expansion vessel believing that it must be blocked. It wasn't and decided to fit a second new expansion vessel on the very slim chance that there was a fault with the first new one. Still hasn't solved the problem. Its had 3 expansion vessels now.
He has removed the filling loop to see if there was any pressure passing (getting) into the system via the loop. I am testing this at the moment by cooling the system right down, setting the pressure to 1 bar and then firing the boiler up to temperature with the filling loop disconnected to make sure there can be no pressure introduced via the filling loop valve.
My plumber is very experienced and professional and he is quite speechless and stumped as to what the problem is !!
The heating system is indirect ( I think thats what its called !!) ie. the system boiler heats a coil in the Domestic Hot Water tank. He is now wondering if the coil has failed, the DHW cylinder vent could be blocked, and my shower pump is introducing some pressure back into the boiler flow system. He is grasping at straws at the moment.
I have got faith in my plumber but I thought I would post this problem here just in case anyone has any ideas !!
My concern is that my wife and I are going on holiday tomorrow for 10 days and my 21 year old son will be on his own. I don't really want to leave him with this problem unsolved.
Any thoughts, suggestions or ideas are welcome !!
