I hope someone out there can help......?
I have an Ideal m30100 boiler which has worked fine for the last 5 years but has now decided to stop supplying central heating....?
The boiler kicks in fine when demand for hot water is needed but will not heat the central heating system.
I have a seperate Digistat which controls the times and tempretures needed ect which seems to be working fine...? but not sure if the signal is, a: reaching the boiler or, b: the boiler is receiving the signal but the PCB is not working....?
Has anyone had a similar problem solved or does anyone know of an inherent fault with these boilers...?
Alan. :
Alan. :
