Boiler problem
21 Aug 2010
Yorkshire
Hi
my vaillant Ecomax 824E takes very long time to produce hot water and i am wasting lot of water . Obviously it is a problem and any one out there could give me your expert suggestions please?
WHen you run a hot tap, does one of the heating pipes get hot (fat one, furthest left)
Dear Chris
It is my daughter's boiler in London and am in sheffield.I am going over on 5th sept and findout more. Thanks for your reply. Puvan
If there are no faults, the trick is:
Run the hot tap slowly - just fast enough for the boiler to recognise the demand - until it runs hot, then increase to the desired flow rate. The boiler will heat up from cold more quickly that way.
Does your daughter have the preheat function enabled?
This is indicated by a 'C' in the LCD display.
If there is no 'C' she needs to turn the top knob (identified by a tap graphic) fully clockwise, leave for two seconds, and then turn back to normal. The 'C' will then appear.
Without preheat, your boiler will have to go through its' ignition cycle before it begins to warm the water, giving a delay of 10 secs or thereabouts.
Disadvantage of preheat is that it uses a small amount of gas to provide this convenience - so you either 'waste' gas or water!
