Boiler problem
30 Aug 2012
Hi was at a ariston microsystem 21 rffi .boiler is not sparking. So I checked fan pump air pressure switch all is ok.i checked power going to gas valve was getting 460 v with the lead connected and 230 v with the lead disconnected from the solenoid, and there is no gas coming out of the outlet side. Not sure if it's the gas valve or the ignition pcb .
You'll have to ask this in the Combustion Chamber I'm afraid Ollie, we don't give gas advice on the open forum. To get in, send your Gas Safe Registration Number to Admin
