Boiler problem
27 Jul 2007
I have a halstead finest gold boiler,then i switch the C.H on it pressurises right up .
Could it be the exspansion vessel ,if so would it be possible to put a new one in line :?:
Yes, you can.
It would be best to check if the old one has lost it's charge, whether the diaphragm has ruptured or the connecting pipe is blocked before doing this though.
You never know, you might just need a foot pump to fix it.
If you press on the 'car tyre' type valve on the expansion vessel and water comes out it is knackered.
Thank you for your help EliteHeat and Gas4you , i will tell you how i get on .Once again thank you. :)
