Boiler Programmer Installation
8 Mar 2008
Lancashire
We have a back boiler which is currently controlled by a Danfoss Randall 102 GP mini programmer. I'm looking to install a new digital programmer and was wondering how easy it would be to replace it with a Danfoss FP715? Would it be wiser to get the 102E5 instead?
Can you run your central heating CH separate from your domestic hot water DHW?
This Danfoss FP715 is what I've just got to replace an ACL SM400 on a Gravity DHW Pumped CH. Until I fit and wire-in a valve and stat at the cylinder, the CH has to be programmed to operate (when required) during periods in which the DHW is set. As it is with my C plan system the DHW contact switches a live to tell the boiler to heat.
102 GP manual - http://www.heatingcontrolsonline.co.uk/instructions/102.pdf
FP715 manual - http://www.heatingcontrolsonline.co.uk/instructions/fp715si.pdf
Regards
UF
