boiler scrappage eligibility ariston eurocombi sx20 mffice
28 Aug 2009
London
Hello - does anyone know if the Ariston eurocombi sx20 mffice is eligible for the scappage scheme? I can't find it on any boiler lists anywhere to see what it's rating is. Many thanks.
I read somewhere that G rated boilers have pilot lights and not ignition system . Hope that helps a bit...
ATB.
ATB.
Think that might be a general rule of thumb but not definite (hope so anyway as mine has ignition but is 12 years old, not working properly and need new one. Thanks, Shivaun.
I Found an installation manual on Ariston web site:
http://www.ariston.co.uk/uploads/doc47f5fb3f1e77d.pdf
On the front page it says its a type C, probably not helpful but it does say in the manual that the boiler has a secondary heat exchanger so I think its not going to be a 'G rated'. Its probably higher rated than my Potterton Suprima that does not have the secondary heath exchanger and is rated D.
ATB.
Do you know the GC (Gas Council) number? It will be on the data plate.
The Sedbuk database has many errors and omissions, a mixture of incorrect data provided and inputting errors.
All manufacturers should go through their entries and make sure they are correct, particularly for older boilers. Names and model numbers, in particular, do not always agree with what is shown in installation and user manuals. An example is the Baxi Solo 2, which does not appear anywhere in the database.
Yes, it's 47 116 02.
Thanks, Shivaun.
