boiler settings
4 Nov 2003
this site is fantastic. so many folk giving good advice so we dont get ripped off.
live in bungalow with ch system new 9 years ago. the boiler is a ideal classic ff260 whatever that means. can you tell me the best setting one to six to put it at and what temp should the water cystern be set at ?we got 7 rads on the cicuit so what no. the pump want to be 1 2 or 3 ?
next problem is the power shower, i think was fitted by cowboys. were on the 2nd £400 mira pump. its in the loft so it has to draw water up then pump down to the shower. if we turn the shower off quik it starts the pump going on and off for ever unless its turned back on and then off very slow. ther is a brass bell like thing with a valve on it attached to the pump hot supply , is this some kind of air thing? if so should it be loose or tighted down, also on the ch pipes and near boilrer there is two similer valves ,should these be vented now and again or left alone. many thanks till next query.
for the pump setting do a search on pumps
as for the power shower sounds to me like the flow switch is fualty are you still in warantee if so call aqualisa and they will sort it out. if not think about getting a new ppump as 9 times out of 10 it works out cheaper than repairing
