I'm looking to replace a gas-fired 100k BTU AGA-type range cooker / boiler with a modern gas boiler (and an electric fan oven !) but am uncertain which size to go for. Ignoring the oven, the radiators around the house total to around 60k BTU (each with a thermostatic valve) and the house warms up quickly whenever the heating comes on, so allowing for the water cylinder I assume around 80-90k BTU is what I'll need. However the heat output range quoted for condensing boilers seems very wide : for example, the Worcester Bosch Greenstar 30CDI quotes 26 - 102k BTU, which I assumed would be fine. However the WB website describes this as for small - medium sized houses and recommends the 50% more expensive 40CDI (output range 32k - 140k BTU) for a 4-5 bed house like ours.
Is it really advisable to go for the bigger boiler, even if it's rarely going to be called upon to run at much more than half its maximum output ? Or put another way, is there an obvious downside (in terms of efficiency, life expectancy, ...) of specifying a boiler to run at closer to its maximum output ?
Any guidance much appreciated.
