I have a Baxi Duo-Tec Combi 40HE.
The last few days I have noticed a lot of condensation/air coming from the flue. I checked the boiler with the intention of reducing the maximum temperature going to the rads to reduce the condensation but found that the thermostat on the boiler is cycling between 49-53 degrees. Usually it's set at 65 when heating the rads and drops to around 53 on the return phase. When I try to adjust the boiler temperature its changing so rapidly its impossible to see what the temperature is.
The boiler is currently still coming on when heat is called for by our Cosy thermostat. Is it as simple as replacing the boiler thermostat or do I need to so something else?
I'm competent at performing most easy tasks on the boiler - new pumps, chemical flush, fixed a seized return value.
