- Joined
- 13 Mar 2016
- Messages
- 43
- Reaction score
- 0
- Country
Hi all. Apologies for the long post.
I have been having some central heating issues recently....started after I had to drain down the system after a leak, refilled and ever since has been problematic. However I have always had problems with this system and have needed to run the pump on full speed to get 3/4 of the rads warm (and then never particularly warm)
Anyway, in my travails I have:
1) reinstated old separate feed and vent pipe on the advice of a local plumber (had been installed with separate feed and vent but someone in the past had capped off the vent and combined them). I was told this would make it easier for the system to clear any air locks...made sense to me as given things got worse after a drain and refill air locks seemed likely culprit
2) backfilled the system twice via the draincock, drained and refilled. Flushed out several of he more problematic radiators. I have automatic vents fitted on both the CH and hot water circuits after the 3 way valve (its a Y plan system). Have bled everything multiple times.
3) Added CH system cleaner and ran it through groups of radiators for several days at a time
4) Removed old pump as anticipated it would be gunged up. It was not, but replaced anyway with a grundfos UPS3.
At this point I had hoped that maybe old pump was just a bit knackered but putting in new pump doesnt seem to have made any difference ( as i was warned by some on this forum it may not!)
everything fires up straight away, 3 way valve seems to be working correctly. However boiler comes on for only a few minutes a time, whether its the hot water cylinder thats being supplied or whether its the rads. It comes on for longer when it goes to the cylinder vs the rads (usually about 3 minutes to the cylinder, 2 minutes to the rads). It then switches off for a few minutes and then comes back on again in a similar pattern
I had assumed this was because the boiler was reaching its max temp ( which I think should be about 80 degrees right?) too quickly because of poor flow round the system due to sludge.
However Ive now checked the temperature of the feed and return pipes when it comes on. When the boiler comes on the feed pipe is at about 30 degrees. It seems to shut off consistently at about 52 degrees without fail. I have not seen it get any hotter than that.
I initially thought maybe it was the honeywell programmer not calling for heat consistently, so timed it as surely if it was the programmer there would be a time dependent pattern to the on/ off - but this does not seem to be the case as if I turn the boiler temp down it goes off for longer etc..
Basically Ive come to the conclusion that the boiler is shutting itself off due to an error reading the temperature that the feed pipe is getting to.......and the reason my CH has been so crap is that my pump spends alot of time circulating cool water around the system when the boiler is off......
Any thoughts?
Any thoughts?
