- Joined
- 11 Oct 2011
- Messages
- 20
- Reaction score
- 2
- Country
Boiler thermostats have been much discussed but I haven't found the precise answer to my query. I know the stat determines the heat of the water flowing out of the boiler. But how?
My understanding is that the boiler burners always operate at the same pressure and that different water temperatures are achieved by the boiler thermostat switching the burners off when the desired (boiler) temperature has been reached - irrespective of whether the room thermostat is still calling for heat. So at a low setting on the boiler dial, the room temperature may never be reached, whereas with a high setting, the room thermostat may switch the burners off before the boiler thermostat does.
So is this right or wrong? Wrong, according to Ideal Technical Helpline. They told me that the boiler is only triggered on and off by the room stat (and this will happen sooner if I turn the boiler stat up). If this is true, what is the function of the switch within the boiler thermostat and when would this be activated?
The thermostat on my Ideal Minimiser SE60 condensing boiler seems to me to have stopped switching off so often - even at a setting below 1 it can be over half an hour before the boiler switches off, and as long again before it switches back on. Nevertheless it is the boiler stat that is switching the boiler off - the radiators are very hot but the room temp has not yet reached the room stat setting (turning the room stat down does turn the boiler off). So that seems to contradict Ideal's explanation.
I have tried running the boiler at maximum (number 6). Even after an hour the boiler had not switched off once. So I turned the boiler stat dial back and it clicked off at just below number 2. But turning the it back up, it did not click on again until I reached maximum.
Any light shed on this gratefully received!
Thanks.
Thanks.
