I'm having problem with a potterton boiler and stat. The boiler is firing up
when the timer is in Off position. With stat clicked on. A customer brought a stat to replace a broken 1 and i fitted it. This is when the problem started. I fitted a Sunvic 4101. When i fitted it the 3amp in the spur blew. I replaced it and changed wiring and all was ok apart from the problem stated. So i found which stat it should be and replaced it for that one and the same thing is going on. The stat is a T6360 1036B.
