Hello I'm having a problem with my boiler. It won't turn on!
It is a storage boiler - and the element unit was replaced by an "expert" at the beginning of the year. Now its broken already!
I've disconnected it from the mains and I've used my continuity tester to try and located the problem. I think its this device which says 'LC T24' on it - it has two pins connected on the live circuit and a weird black pin that seems to move but does not do anything (It doesn't click, just seems a bit loose). What does this thing do? Can I fix it easily, or perhaps buy one of these and replace it myself?
My old boiler element had a trip reset button - but on this unit there doesn't seem to be anything like this.
Also for reference I've tested the following on my continuity tester and they all conduct electricity just fine:
- The heating element
- The thermostat with an adjustment for what temperature to turn on/off.
My unit has a sticker which could be a product Id: D631 966
The live wire first goes to the termostat, then to this weird LC T24 device and then to the element. All parts conduct electricity except for the LC T24 device.
Any advice?
Cheers
Any advice?
Cheers
