    Dismiss Notice
Bolier Problem
Discussion in 'Plumbing and Central Heating' started by ukmercenary, 31 Mar 2020.
  1. ukmercenary
    ukmercenary
    18 Oct 2009
    222
    Thanks Received:
    2
    Hampshire
    Country:
    Hello
    I have a Greenstar 25Si Compact NG Condensing Boiler.
    Fairly regularly I have to top it up with water to keep the water pressure at a certain level.
    This morning I noticed the little lever at the bottom of the boiler was a lot stiffer (i suspect after my last boiler service he scrwed something up as my smart meter has stopped receiving meter readings the day after he left) .
    The problem is that the water pressure keeps on going up and the lever is stuck. I have turned the boiler off now which has stopped it.
    What can I do my self to fix this?
    I don't really want to have to spend £100's
    UPDATE, ive turned it back on and the preassure is not going up ...ill look to get someone out to fix it
    Cheers
    Paul
  2. Nozzle
    Nozzle
    23 Dec 2012
    2,199
    Thanks Received:
    289
    Suffolk
    Country:
    • Thanks Thanks x 1
  3. Sponsored Links
  4. ukmercenary
    ukmercenary
    18 Oct 2009
    222
    Thanks Received:
    2
    Hampshire
    Country:
    ok thanks, looks like I will have to use my British Gas home care to get it working.
  5. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,937
    Thanks Received:
    1,981
    Hertfordshire
    Country:
    As a mercenary, I'm sure you could sort this out?
    Andy
    • Like Like x 1
  6. Sponsored Links
  7. Nozzle
    Nozzle
    23 Dec 2012
    2,199
    Thanks Received:
    289
    Suffolk
    Country:
    I'm guessing not in the A-team
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
