Hello
I am currently doing an electrical course at college and have a query reguarding TT circuits.
This is the scenario :
For my theory project i have to imagine i'm wiring a detached building.
It will consist of a new Consumer unit ( 1x 6amp breaker and 1x 16amp breaker) which will feed 4 x 2gang sockets in a radial circuit and one Two way light set up (1x Strip light).
The consumer unit it connected to the main house Consumer unit on it's RCD side by 4mm SWA (3 core).
Where i'm stuck is, as the SWA has an earth attached from the main Consumer unit to the New detached building unit, do i connect the Earth OR do i need to install a Earth Rod (16mm or 10mm Bonding) instead ?
In other words, do i :
A) leave just the Earth from the 3 core SWA attached ?
B) Disconnect the SWA's earth and fit a bonding to an Earth rod ?
C) Attach the both of these (i beleive this is wrong due to conflict to the RCD?) ?
I hope i've explained my question enough.
Thank you.
Thank you.
