I'm hopefully going to be rebuilding the stud wall that I removed that was the original meter position but I need to reroute the Feed and Return pipes from my CH Boiler to facilitate this.
Now I know that there isn't any specific bonding to the boiler, seeing as the gas pipe is directly bonded downstairs but if I break the continuity of the copper pipe with plastic, would it be good practice to run an earth wire from each end of the change in pipework to keep any bonding that's associated with the water side of the CH ?
It won't be a problem having the terminals on show as the pipework is going to be totally accessible being surface mounted in a corner of the new cupboard that the wall rebuild will create.
Thanks as always
Thanks as always
